Activity Forums Apple Final Cut Pro Legacy Mixing PAL625/50, 720p50 and 1080i50 for a PAL DVD release
  • Mixing PAL625/50, 720p50 and 1080i50 for a PAL DVD release
    Posted by Mark Wallaard on April 7, 2009 at 9:05 pm
    We are editing a multicam concert from 7 different camera’s.
    5 HDV 1080i50 (25fps; upper fields)
    1 XDCAM EX 720p50 (25fps; progressive)
    1 XDCAM PAL 625/50 (25fps; upper fields)
    The master of the edit should be an uncompressed PAL file, ready to be processed for distribution on DVD and broadcast on TV.
    We plan to edit in low res first, with 7 dv pal files (our hdd’s can’t handle 7 uncompressed tracks), and then reconnect them with the higher quality uncompressed files later.
    I want to downconvert the HD files to PAL first. The film will never be released in HD so it’s easier (and more hard drive friendly) to work from and master in PAL files. What concerns me most is the field orders. I did a test and all the footage from the 720p50 camera would strobe on the tv. The interlaced files (after swapping the fields to lower) would give smooth camera movements.
    What is the best way to convert these files to uncompressed pal? Which field order should I use when aimed at creating a master for DVD? And what is the best way to implement the 720p50 files in the PAL edit.
    Thanks in advance.
    http://www.zimati.com
    Rafael Amador replied 17 years, 5 months ago 2 Members · 3 Replies
  • Rafael Amador
    April 8, 2009 at 2:33 am
    Hi Mark,
    With that kind of footage and a medium performance machine I wouldn’t bother in transcoding nothing.
    If the most part of your footage is Upper first, edit in an Upper first sequence.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Mark Wallaard
    April 8, 2009 at 3:40 pm
    Thanks Rafael. Should I transcode the 720p50 to a PAL upper field first? When I made a test dvd from an upper field sequence, the720p50 footage gave judder on the TV, the other footage moved smooth as butter. I can use a high end system for the rendering and transcoding of files. We just had to edit it on a medium performance machine due to budget constraints.
    Mark.
  • Rafael Amador
    April 8, 2009 at 5:04 pm
    Hi Mark,
    I work with DV, HDV and XDCAM with a MBP an some fast HDs and no problems.
    I have never worked with p50 footage, but it shouldn’t be any problem when dropped in a i50 sequence.
    FC should take a field from each frame and get a perfect i50 movie.
    Make a test, but It should be that easy. the other way around would be by re-interlacing but this would be more time consuming.
    Rafael
