Activity Forums Apple Final Cut Pro Legacy mixing interlaced and progressive
  • mixing interlaced and progressive
    Posted by Anthony Faulkner on August 14, 2010 at 1:48 pm
    I have a variety of footage I have to mix together.
    XDCAM 1080P footage and
    DVCAM interlaced (I’m not sure the size) But it is 16:9
    As it is for internet viewing I would like to edit and output in progressive. How should I go about converting the DVCAM footage that I will receive on DVDs. to a progressive format?
    Rafael Amador replied 16 years ago 3 Members · 4 Replies
  • Rafael Amador
    August 14, 2010 at 2:56 pm
    Hi Anthony,
    Edit the footage together in a Progressive sequence and drop a de-interlacer in the interlaced clips.
    Avoid the FC default de-interlacer.
    rafael
    http://www.nagavideo.com
  • Bret Williams
    August 14, 2010 at 5:58 pm
    To keep the highest quality, you could edit in a 1080i sequence and have the 480i footage unconverted to 1080i. Then, simply export and use compressor to convert for the web. It does the deinterlacing.
    But that would be overkill if the final is ONLY for the web. You could skip the upconvert and edit in a 480i anamorphic sequence and then export that to compressor.
  • Anthony Faulkner
    August 14, 2010 at 11:56 pm
    Thanks for the replies.
    If not the FCP one what do you recommend?
    Anthony
  • Rafael Amador
    August 15, 2010 at 1:52 am
    Nattress or FieldsKit.
    Both works in 10b.
    rafael
