Activity › Forums › Apple Final Cut Pro Legacy › Mixing interlaced and progressive on timeline – how to set footage priority?
  • Mixing interlaced and progressive on timeline – how to set footage priority?
    Posted by Niklas Wikman on October 14, 2013 at 2:24 pm
    Here’s my problem:
    Footage #1 1280×720 PAL@50fps 720P50, DVCProHD codec
    Footage #2 720×576 PAL@25fps, DV50 codec
    Timeline is set for footage 1: HD960x720 with DVCPro HD 720P50
    After compressing to MPEG-2, I realise that I have problems with motion in footage 2 (which is sign language).
    So I figure I must change the timeline setting to match footage #2 instead? I realise I will loose ftps, but I guess that playing progressive footage in an interlaced timeline is better than playing interlaced footage in a progressive timeline?
    Any help on this is greatly appreciated!
    Niklas
    Rainer Wirth replied 12 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
  • Rainer Wirth
    October 14, 2013 at 2:52 pm
    All footage must be either 25 f/s or 50 f/s. I would transfer the whole stuff on 25f/s through Episode using ProRes codec. Then everything cuts nicely including a decent color correction.
    cheers
    rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Niklas Wikman
    October 14, 2013 at 2:57 pm
    I do have Episode (both Episode 5 and Episode 6).
    Exporting from FCP to ProRes would not be better, then?
    What settings do you suggest I use in Episode, bringing a ref movie from FCP? And – ProRes could either be interlaced (upper/lower) and non-interlaced. What should I choose in Episode?
  • Rainer Wirth
    October 14, 2013 at 4:02 pm
    Here you go:
    Convert this footage to ProRes422 1080i (1920×1080)
    The quality of the DVCPro50 material is acceptable (if progressive!)
    Episode is the best conversion programme to me.
    Your timeline then will be ProRes422 Pal
    In case your DV footage is 4×3 I would choose a 720p codec or transfer this through FCP into a 16/9 sequence (you have to enlarge the picture and set it into frame).
    cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Niklas Wikman
    October 14, 2013 at 4:14 pm
    Thank you Rainer,
    I’ll convert the footage using Episode and then I hope I can just re-connect my media (not having to re-edit it all…)
    But the DVCPro50 footage (with sign language is interlaced. I’m not sure it’s good idea to blow it up to 1080i…?
    Niklas
  • Rainer Wirth
    October 14, 2013 at 6:07 pm
    Yes it is. We do that a lot with material we shot years ago. The problem you will have is the timecode in case of reconnection to the timeline. Try it with two clips first.
    cheers
    Rainer
    By the way, getting all your clips on the same framerate and codec before you start editing must be part of your workflow. So you have to pay a little suffering money to learn a professional workflow. We’ve payed for it too.
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Niklas Wikman
    October 14, 2013 at 7:12 pm
    Rainer,
    Thank you for your patience – this is the first time I have two different footages that must reside in the same timeline.
    Should I simply pick the ProRes 422 1080 encoder in Episode and give it a go? No other parameters to be set?
    I can’t see anywhere in the encoder settings (in Episode 6) that it will be 1080i ProRes…
  • Rainer Wirth
    October 16, 2013 at 2:42 pm
    yes,
    this is how you can do it,
    cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
