Activity Forums Apple Final Cut Pro Legacy mixing interlaced and progressive footage
  • mixing interlaced and progressive footage
    Posted by Phil Sheldon on January 11, 2011 at 2:22 pm
    hi there all. I’m currently using a little sony HD camcorder 1080i and a canon 60d 1080p in FCP. even if i set teh timeline to the sony interlaced footage and accept that i have to render every 60d clip as i go, the end output is still a bit juddery in places.
    is there any procedure i should be following here? or should i just not be using the sony and just concentrate on using the progressive footage? at present i am experimenting to try and find a solution as budgets (i.e. my boss) won’t let me go and buy a serious progressive HD camcorder which is just unfair in my book!
    anyhows, any guidance most appreciated
    thanks
    Phil
    Phil Sheldon replied 15 years, 4 months ago 2 Members · 2 Replies
  • Chris Tompkins
    January 11, 2011 at 3:37 pm
    Take the format with the least amount of footage and run the shots thru compressor and convert to I or P which ever the case may be. Matching the other formats clips.
    Then import the clips into the proj.
    Chris Tompkins
    Video Atlanta LLC
  • Phil Sheldon
    January 13, 2011 at 2:12 pm
    thanks for the guidance, will try and get to grips with compressor as i’ve been ignoring it so far!
