Activity Forums Adobe Premiere Pro Mixing HDV and DVCAM
  • Mixing HDV and DVCAM
    Posted by Rajarshi Basu on September 5, 2006 at 6:03 pm
    For my documentary I have both HDV and Dv footage.IM editing on PPro 2. How is it possible to work with multi format clips in the same project ?
    Or do I have to export the either of the clips as AVI and then import them back in ? But thats a pain as I have around 7 hours of material.
    Any suggestions ?
    Pedigree-punk replied 20 years ago 2 Members · 3 Replies
  • Pedigree-punk
    September 6, 2006 at 8:38 am
    I’m currently mixing PAL HDV 1080i 7 PAL 16:9 Widescreen in a PAL 16:9 Project – I can scale and re-frame the HDV to fit the SD project. It’s slow, but works on a P4 3.6ghz with 1 MB of Ram. If you want fast performance and don’t have a kick-*ss machine, I’d say you would be best of turning your HDV into SD avi’s – unless you want to make use of re-framing and zooming in on the HDV footage.
    In order to discover new oceans, man has to leave sight of the shore.
  • Rajarshi Basu
    September 6, 2006 at 9:04 am
    Ya…but I want to know how u are mixing SD with HDV. Do u export either the HDV or SD material as avi…and then import them in …in a project ?
  • Pedigree-punk
    September 6, 2006 at 11:14 am
    The Project is 16:9 SD,I import SD DV avi (Premiere Captures from DVCAM) and native HDV MPEG2 files(HDV captures from another app). Premiere indexes the HDV files for a while, then I can drop them in the timeline. Hope that helps….
