Activity Forums VEGAS Pro Mixing HD Video formats in Vegas – Need your suggestions!
  • Mixing HD Video formats in Vegas – Need your suggestions!
    Posted by Dave Petteruto on August 3, 2012 at 10:00 pm
    I recently purchased a Panasonic HMC-40. I shoot a lot of football and will be shooting video from the Panasonic using the 720/60p format. I like that format because it does a nice job with little blurring on the fast motion shots.
    I need to purchase another (less inexpensive camera) that I can use for random game shots. These shots will be mixed into Vegas with the 720/ 60p video (I use Vegas 10). I can’t find a camera in my price range (under $700) that shoots in the 720/60p format. So I’m looking for suggestions on what format would mix well with the 720/60p and give me the best quality. Most of my work will be put onto DVD, so keeping the HD format is not a major concern.
    One camera I was looking at is the Panasonic HC-V700. It shoots in 1080/60p. Would this be a good fit?
    Any thoughts or suggestions would be very much appreciated.
    Dave P.
    Intel I7 950, 12GB RAM, NVIDIA GeForce GTX 460 SE, Vegas Pro 10 (32bit/64bit), Windows 7 Pro 64bit, LG WH10LS30 10X Bluray Burner.
    Dave Haynie replied 14 years, 1 month ago 3 Members · 2 Replies
  • Steve Rhoden
    August 4, 2012 at 12:21 am
    Yes Dave, the Panasonic HC-V700 would be a good and
    affordable choice for the task you want it to do.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Dave Haynie
    August 18, 2012 at 6:21 am
    Yup. I have a Panny TM700 as the “B” camera to my HMC-40.. it even uses the same battery standard (I have a cable to let me use the big cell on the TM700). The 1080p60 mixes just dandy with the 720p60 from the HMC-40.
    The V700 is more of a mid-range model, and Panny changed the battery for their consumer models after the TM700, which seems arbitrary and annoying (the standard used on the TM700 and HMC-40 also worked on my daughter’s SD-9, a camera I bought her used when she started “Communications Academy” in high school), but they have a number of great improvements on sensor sensitivity and “hybris” stabilization (optical for X/Y, digital for Z-roll… makes a ton of sense). Not a non-issue… if I have both cameras, I’m probably using both on tripods, or the HMC-40 on my Glidecam. But sometimes I just grab the TM700 alone, and then it’s more likely to be a handheld thing. The OIS make that a useful thing to do.
    -Dave
