Activity Forums Blackmagic Design Mixing HD and SD?
  • Mixing HD and SD?
    Posted by Ryan_j on June 28, 2007 at 11:22 pm
    I was after some advice if possible. I’m looking to do a shoot in Hi-Def
    soon and i’ll be editing in Premiere Pro with a multibridge pro using a mixture of HD and SD. The final OP is for a SD TVC and i wanted to know the best way of mixing the two formats while getting the most out of the HD vision. I would appreciate any advice. Thanks Ryan.
    Ryan_j replied 19 years, 2 months ago 2 Members · 2 Replies
  • Steve Wargo
    June 29, 2007 at 6:48 am
    Are you talking about mixing 4×3 with 16×9?
    My only advice would be to downconvert the HD using a center cut (or possible a letterbox) so that everything is matched, unless you don’t care about the different aspect ratios.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut Pro systems
    Sony HVR-M25 HDV deck
  • Ryan_j
    July 2, 2007 at 1:11 am
    Hi Steve, thanks for you help. I’m using all 16:9 but a mixture
    of HD and SD. I was just wondering if i should try and upscale the SD
    or down covert the HD to SD for the edit?
