Activity › Forums › Apple Final Cut Pro Legacy › Mixing Frame rates in One Sequence
  • Mixing Frame rates in One Sequence
    Posted by Christopher Dalrymple on May 2, 2010 at 7:27 pm
    And now for the dumb question of the day.
    I’m helping an actor friend with his reel which will go to DVD as well as uploaded to some websites. Trouble is his Quicktime clips (ripped from DVDs) are in different frame rates and one (mine) is HD.
    1. 59.94 fps, 720×404, DV-NTSC, Square Pixel
    2. 23.98 fps, 720×404, DV-NTSC, Square Pixel
    3. 23.98 fps, 1440×1080, ProRes422, HD
    4. 29.97 fps, 640×480, DV-NTSC, Square Pixel
    Which clip becomes the one all others are converted to?
    Christopher Dalrymple replied 16 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    May 3, 2010 at 2:12 am
    [Christopher Dalrymple] “Which clip becomes the one all others are converted to?”
    Whichever you use first…that sets the sequence settings to match that clip. After that, all the other clips added will be set to that frame rate. BUT, FCP does a HORRID job of mixing frame rates. Adds the wrong pulldown. Best to use Compressor to convert everything to the same frame rate.
    Shane
  • Christopher Dalrymple
    May 3, 2010 at 3:08 am
    Thanks, Shane. Just needed the reassurance.
