Activity › Forums › Apple Final Cut Pro Legacy › Mixing footage in the same sequence
Posted by Rui Coutinho on January 13, 2010 at 4:57 pmHi !!
I have footage from Sony EX3 and from RED in 2K
is it possible two mix those two formats in the same sequence in FCP 6.5 ??Thanks!!
Rui Coutinho replied 16 years, 7 months ago 2 Members · 4 Replies -
Michael Sacci
January 13, 2010 at 5:13 pmHow much of each, a little ex3, a little RED, equal amounts of both?
Michael Sacci
January 13, 2010 at 9:37 pmSince RED footage is either converted to ProRes with Log and Transfer or the sequence setting’s compressor is normally set to ProRes, I would convert the sony footage to match the ProRes specs you use for the RED footage. That will give you the lest amount of rendering during editing.
Rui Coutinho
January 14, 2010 at 11:34 amThanks!!
But I have another question,
Since I got two different resolutions one from EX-3 1080×1920 and the red 2K,
my final resolution will be 1080×1920, cause I cant go further in resolution with the EX-3 material.
So the red 2K will be down sized to 1080×1920,
that´s correct?Thanks again !!
Rui
