Activity Forums VEGAS Pro Mixing field order settings
  • Mixing field order settings
    Posted by Paul Gregory on February 27, 2014 at 12:59 am
    If you have original footage some of which is progressive & some that is not what options should you select for rendering output to Blu-ray?
    Thanks in advance
    John Rofrano replied 12 years, 6 months ago 2 Members · 1 Reply
  • John Rofrano
    February 27, 2014 at 2:45 am
    Blu-ray expects interlaced footage because TV sets still support interlaced footage so I would render interlaced unless you are rendering to 24p in which case you can render the whole thing as progressive. The interlaced footage will probably look better as interlaced and the progressive footage should look just as good when interlaced because both fields will carry the same information.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
