Mixing EX3 & SD in same timeline
Hi there,
Were starting to use EX3 footage into our existing SD work flow. Most of the footage is SD, the timeline is SD & we’re mastering to SD tape.
When I drop a EX3 clip on the timeline, it looks soft & strobed, even after I set the render to best. Do I have to convert the footage to SD before I use it? In Compressor? Is there an easier way?
I have FCP 6.0.6 and Kona LHe.
