Activity › Forums › Boris FX Particle Illusion › Mixing Emitters
  • Alan Lorence
    January 22, 2006 at 5:32 pm
    Open the properties dialog for the library that contains both emitters. Then in the hierarchy of the properties dialog, drag the particle type from one emitter into the other emitter.
    Note that the results may not be exactly what you expect, since the emitter properties (which act as a scale factor) are probably different for both emitters.
    Alan.
    wondertouch
