Activity › Forums › Blackmagic Design › Mixing dv and sd on the same sequence without rendering
Posted by Göran Thorén on August 23, 2005 at 1:13 pmIs there a way?
Andrew Mcleod replied 21 years, 1 month ago 3 Members · 3 Replies -
Franklin Beaver
August 23, 2005 at 3:02 pmNot with FCP. Not sure about other products but I do know that NewTek’s VT4 can do it real-time. It can play back almost any video file as long as the codec is on the system. Works great for mixing DV and analog-captured footage in the same timeline. Sure wish Final Cut could do it.
Franklin
Göran Thorén
August 23, 2005 at 3:41 pmHmmm… Not good… I thought there was a way to interpret the field order in FCP.
I -
Andrew Mcleod
August 24, 2005 at 3:24 amHi
FCP will play Uncompressed and DV on the same timeline if your system can cope and you enable unlimited RT effects. Premiere Pro 1.5 of PC also.
Andrew McLeod
Blackmagic Design
