mixing different sources together (HD/SD, i,p, pal ntsc)
Hey guys,
I recently had a very complicated edit process. I was supposed to edit a showreel for a production company and got all kind of material to begin with (PAL, NTSC, interlaced, progressive, HD, SD)
The most part of the footage was uncompressed PAL, interlaced so i decided to make my timeline 1024×576, upper field first, palBecause of time issues i couldnt convert any of the progressive material and so i was forced to just start editing right away. I ouput the material as a pro res version and he was happy with it.
When I look at the finished shoreel now there are obviously the interlace lines on fast movement for a majority of the clips. but some are definately progressive clips. I had major issues with a project like that before where we exported the finished video to digibeta. when we played it back on digibeta half of the film was stuttering, the parts which had the wrong field dominance i reckon…What I wanna know basically is how you guys handle mixed footage. In the apple documentation it only said that “Final Cut Pro is not the best environment for converting one field-handling standard to the other.” (https://documentation.apple.com/en/finalcutstudio/workflows/index.html#chapter=5%26section=3%26tasks=true)
But when i have time pressure and have to do everything in a final cut sequence how would i get the progressive material to be interlaced? does that even make sense or is it often better to work with a progressive timeline and use the de-interlace filter on the interlaced clips… and when exporting to tape to re-introduce interlacing? I’m confuesd 🙂 Thanks for any help on this issue…
