Activity Forums Apple Final Cut Pro Legacy Mixing Diff Frame Rates & Resolution in Sequence?
  • Mixing Diff Frame Rates & Resolution in Sequence?
    Posted by Erika Brekke on May 26, 2011 at 7:59 pm
    Hi-
    I’m new to working with different frame rates & resolution in one project & need some advice. I just inherited footage from 3 sources all shot differently and am editing in Final Cut 7.
    Here’s a breakdown of the footage I have:
    1440×1080/29.97fps
    1280×720/59.94 fps
    960×720/59.94 fps
    What’s the best way to get this footage uniform? Use Compressor for frame rate conversion & then re-import to FCP? Is it better to convert up or down? (Sorry, I’m new!) And is there a tutorial you recommend on that?
    Finally, what’s the best codec to use? And should I be using the lowest res for a seq setting?
    Sorry to be dense & thanks in advance!
    Jeff Greenberg replied 15 years, 3 months ago 3 Members · 3 Replies
  • Chris Tompkins
    May 26, 2011 at 10:33 pm
    Start Here: 1440×1080/29.97fps
    Use that sequence.
    Drop the others in and it will be fine.
    Chris Tompkins
    Video Atlanta LLC
  • Erika Brekke
    May 26, 2011 at 11:25 pm
    Thanks, Chris. You’re right – it looked & played fine. As a general rule, should you always set the seq to the highest res? And why did the different frame rates not cause a problem in this instance? I’ve read tons of posts about marrying different frame rates & am trying to learn the science behind it. (I read you should always convert up, but in this case, I plopped the 59.94fps clips into a timeline set at 29.97 & everything seems/plays fine – including when I export.) Thanks again.
  • Jeff Greenberg
    May 27, 2011 at 2:38 am
    I’m simplifying here – but you’ll notice 59.94 is exactly twice of 29.97 – they mix beautifully. It’s mixing with PAL or 23.98 (truly different frame rates) that are painful.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
