Activity › Forums › Adobe After Effects › Mixing Colors red and yellow to make orange
  • Mixing Colors red and yellow to make orange
    Posted by Emmet Reddy on April 30, 2022 at 2:27 pm
    Hi Im working on a job using the master card logo https://en.wikipedia.org/wiki/Mastercard
    im animating two circles together ie red + yellow = orange when i animate together i need to get the orange bit ive tried in various modes i thought screen would work but its not, it works with red green and blue but i can get the orange im looking for by mixing the red and yellow. Anyone have any advice thanks.
    Emmet Reddy replied 4 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Andy Kiernan
    April 30, 2022 at 2:58 pm
    maybe just make the animation of the two circle coming together and then duplicate and matte out the crossed over section and fill orange?
  • Emmet Reddy
    April 30, 2022 at 4:16 pm
    Thanks Andy ill give it a try cheers
  • Filip Vandueren
    May 5, 2022 at 11:29 am
    Using screen you should get something that is somewhat orange, then you can use the “Hue/Saturation” or “Change to Color” effect to get it to the precise shade you want.
  • Emmet Reddy
    May 5, 2022 at 11:59 am
    Yea ive tried that, problem is it changes the whole color ill have to try andys matte suggestion.
    see attached logo mastercard logo. So i will have two balls bounce in red and yellow which makes orange i wish i could tell after effects this, unless im missing something simple, then they will make the logo.
  • Filip Vandueren
    May 5, 2022 at 2:28 pm
    It’s a matter of tweaking the tolerance so only the orange gets selected
  • Thiago Macedo
    May 5, 2022 at 5:56 pm
    I’ve just tried using soft light and worked (red solid on top)
  • Emmet Reddy
    May 5, 2022 at 6:13 pm
    BINGO, Thank you so much Thiago i thought i tried every mode, i had the yellow on top of the red, stupid me never thought to switch around, job done. cheers
