Activity › Forums › Panasonic Cameras › Mixing Canon & DVX100b footage
  • Mixing Canon & DVX100b footage
    Posted by Col. Kurtz on July 16, 2007 at 4:27 pm
    Here’s another question – I am using a Canon GL2 for some footage with a Pan. DVX100b. What should I set the Canon to record in so it will cut together? Letterbox both? I thought Letterbox because then I can uprez to Widescreen if needed…
    Thanks.
    Col. Kurtz replied 19 years, 2 months ago 2 Members · 2 Replies
  • Noah Kadner
    July 17, 2007 at 5:45 am
    Mix how- like a totally different look or interchangeable. The latter is going to be tough with a GL2.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Col. Kurtz
    July 17, 2007 at 10:55 pm
    Don’t mind if it’s totally different – I’m also mixing Super 8 in too.
