Activity Forums Apple Final Cut Pro Legacy mixing cameras and fps workflow
  • mixing cameras and fps workflow
    Posted by Jordi Robert on February 12, 2012 at 6:39 pm
    I’m about to start filming a music video using different cameras and I need to make sure I record using the right settings to get what I want.
    I’m shooting with a Sony HVR Z7E, a Canon DSLR 7D and a Gopro.
    The Canon 7D and gopro will be used for slowdown recording, underwater and timelapse.
    Those are the settings that I think I should be using (Pal)
    The Gopro for slow motion to record 1280×720 50fps
    Canon 7D for slow motion to record 1280×720 50fps
    Sony HDR Z7 to record 1080/25p
    To slow down:
    all 50fps footage to be slowed down by:
    1) Transcode h.264 to prores using mpeg streamclip
    2) Conform Prores footage using Cinema Tools
    3) Edit conformed video in Final Cut
    to transcode all the footage seems a waste of time. should I edit the clips first in FCP as h.264 and then export them to streamclip to transscode to prores?
    Once I have all the slowed down footage and normal speed footage ready to edit in FCP, I will have 2 different sizes of footage 1280×720 (canon and go pro) and the bigger ones from the HDR Z7 which will be 1440×1080 (i think). So, what is best: to set up the sequence settings as 1280×720 and scale down the 1440×1080 or to setup the sequence to 1440×1080 and scale up the 1280×720.
    can I edit a 24 fps shoot on a 25fps sequence?
    I’m also concerned about some footage been interlace and other progressive, will that create problems?
    Thank you
    Shane Ross replied 14 years, 7 months ago 2 Members · 5 Replies
  • Shane Ross
    February 12, 2012 at 8:11 pm
    [jordi robert] “to transcode all the footage seems a waste of time. should I edit the clips first in FCP as h.264 and then export them to streamclip to transscode to prores?”
    It isn’t a waste of time. FCP doesn’t edit h.264 files. It CAN, but not well. Sluggishness…exporting wrong (audio not in sync, not including all of the video). You MUST transcode H.264 to ProRes before you do any editing in FCP.
    [jordi robert] “can I edit a 24 fps shoot on a 25fps sequence?”
    Not well. One frame will get repeated every second, and it will look weird.
    Shane
    Little Frog Post
  • Jordi Robert
    February 13, 2012 at 3:06 am
    Thanks shane.
    Is there a “right way” bring the footage into streamclip? I mean, should I first Log and transfer to FCP and then send to streamclip, or can I just transfer the clips from the Memory card to streamclip?
    Once I have all the clips transcoded to Prores ready to edit in FCP, I will have 2 different clip sizes:1280×720 and 1440×1080 (i think). So, what is best: to set up the sequence settings as 1280×720 and shrink the 1440×1080 or to setup the sequence to 1440×1080 and blow up the 1280×720?
    Thank you
  • Shane Ross
    February 13, 2012 at 3:34 am
    [jordi robert] “Is there a “right way” bring the footage into streamclip? I mean, should I first Log and transfer to FCP and then send to streamclip, or can I just transfer the clips from the Memory card to streamclip?”
    Log and Transfer…if you download the Canon EOS Log and Transfer plugin, FCP will then do this for you. As long as the card structure is intact. If not, use Streamclip. Bring the H.264 files into Streamclip, and render out as ProRes.
    Use a 1920×1080 ProRes sequence. The footage will size properly to fit.
    Shane
    Little Frog Post
  • Jordi Robert
    February 13, 2012 at 3:46 am
    Thanks Shane
    “Use a 1920×1080 ProRes sequence. The footage will size properly to fit.”
    Really? how is that? if I bring a clip 1280×720 to a 1920×1080 sequence, I’m sure the clip wont fill the canvas, logic says that it will be smaller.
    Really appreciate your time Shane.
    Jordi
  • Shane Ross
    February 13, 2012 at 4:40 am
    FCP scales them to fit. The 1280×720 will be like 166% or something. And FCP stretches out anamorphic formats like 1440×1080 to fit.
    Shane
    Little Frog Post
