Activity Forums Adobe Premiere Pro Mixing audio bit rate differences
  • Mixing audio bit rate differences
    Posted by Joseph Freeman iii on January 12, 2020 at 3:07 pm
    Situation: Audio media recorded at different sample rates, 16 bit/44khz, 24 bit/48 khz., 32 bit float-point/192 khz. and the sequence is set to match the final output of 24 bit-48khz.
    Question: Is it best to set the sequence to the highest sample rate to match the best quality media and set the output bit rate in the final render in media encoder
    OR
    Set the sequence to match the final output bit rate in the final render.
    Thank you in advance.
    Joseph Freeman
    Joseph Freeman iii replied 6 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
