Activity Forums Apple Final Cut Pro Legacy Mixing 720p in 1080i sequence
  • Mixing 720p in 1080i sequence
    Posted by Peter Hall on April 2, 2010 at 8:24 am
    I am adding 720p mts footage into a HDV 1080i sequence by importing through L&T (fcp 7) and it seems to play ok alongside the HDV footage. Do I need to change the 1280 x 720p files into 1080 x 1440?
    Peter Hall
    Robb Harriss replied 16 years, 5 months ago 3 Members · 3 Replies
  • Robb Harriss
    April 2, 2010 at 12:30 pm
    you’ll have a lot fewer issues if you make everything the same, less rendering and fewer calls for help later when things aren’t quite “right.”
    Non-linear: all the time and nothing but.
  • John Fishback
    April 2, 2010 at 1:59 pm
    I agree with Robb. You can use Compressor to convert and make sure you enable Frame Controls. Choose the Best quality settings for re-sizing and if the frame rate has to be converted choose Best for that, too. While I’ve never used it, ClipWrap might also help.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Robb Harriss
    April 3, 2010 at 4:07 pm
    John,
    Just glanced at ClipWrap, looks interesting. Fortunately I don’t have to deal with rogue codecs very much at all.
