mixing 32kHz and 48kHz audio
Hello–
I have to cut together material from 2 mismatched cameras: one was set at 16bit audio, the other at 12bit. I can capture OK, by changing the capture and sequence settings for the 12 bit source–is there a clean and direct way to get material from both sources onto the same timeline?
