Activity Forums Panasonic Cameras mixing 24pn, 30pn, and 60p
  • mixing 24pn, 30pn, and 60p
    Posted by Stephani Gordon on August 3, 2008 at 6:46 am
    Apologies if an answer is already out there. I’ve searched and found plenty of similar questions, but nothing that answers my conundrum.
    I’m shooting an hvx200 in a GATES underwater housing. I would *like* to shoot in slight overcrank (I’m a 24pn girl normally) to smooth out bumpy shots and slow the fish motion. Options:
    a- in 720p/24pn mode, up framerate as desired (this works great, but requires I keep the camera on because I can’t access the menu once I close the housing; and battery life is limited when I’m on a small boat for an entire day)- what I used for shore dives, not feasible in my current situation
    b- I tried 720p/30pn mode, and also 720p/60p mode which sticks even if I power the camera on and off; BUT it all imports (for some reason mysterious to me) as 23.98, even if I open a new project, change capture/sequence settings. And that looks much worse than 24pn.
    Any advice? Options I haven’t thought of? Ways to fix issues with above options? I’m out here on a research vessel for another 4 weeks, so I will be super grateful for any help! Thanks!
    Stephani Gordon replied 18 years, 1 month ago 2 Members · 2 Replies
  • Arthur Aldrich
    August 3, 2008 at 11:41 am
    If you save a scene file with the frame rate you desire to one of the 6 built in selectors, then the frame rate will stick even after a power off.
    Art Aldrich
    OTEK TV
    Leader, NJFCPUG
    http://www.njfcpug.org
  • Stephani Gordon
    August 3, 2008 at 5:03 pm
    Brilliant! I’d tried that 6 months ago but I must not have gotten the ‘save’ to stick. I just tried it again, and you’re right- it totally works. Thanks Art. -Steph
