Activity › Forums › Apple Final Cut Pro Legacy › Mixing 24p and 24pA
  • Mixing 24p and 24pA
    Posted by Christopher Dalrymple on July 5, 2009 at 1:47 pm
    I’ve captured both 24p and 24pA to ProRes and am using them in a ProRes timeline with no problems. When I found some of the 24p footage stuttering, I simply picked another frame and the stutter vanished. But when two of these clips are adjacent, the second one cannot be corrected. Any thoughts?
    Christopher Dalrymple replied 17 years, 3 months ago 3 Members · 4 Replies
  • John Fishback
    July 5, 2009 at 3:28 pm
    Checkout this thread. There are others if you search.
    https://forums.creativecow.net/thread/8/1013169#1013226
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Christopher Dalrymple
    July 5, 2009 at 8:16 pm
    Thanks. But as I read it, the thread refers to 29.97 footage in a 23.98 sequence. I have already captured my 24p footage as 24p ProRes. The problem occurs in my 23.98 fps sequence adjacent to another portion of the same clip. Final Cut seems to be having a hard time processing two 24p shots to a 23.98 sequence in succession. Cinema Tools sees nothing to convert or Reverse Telecine.
  • Steve Oakley
    July 5, 2009 at 8:52 pm
    where is the media being stored ? and have you trashed FCP prefs as a first step ? so you have dynamic RT on ? are any clips not gray / green in the TL meaning they need to render ?
    July 6, 2009 at 12:02 am
    Media on separate 2T Raid 0 drive.
    Have not trashed prefs yet.
    The shots in question don’t need rendering. The shots that I fixed by shifting the IN point have green in the render line.
    I’m thinking of perhaps re-capturing the 24p files tomorrow with a MATROX MXO2 someone lent me. It has a setting for 23.98 precisely (unlike the FCP HDV to ProRes capture settings). Will see if that solves the problem.
