Activity › Forums › Apple Final Cut Pro Legacy › Mixing 16:9 and 4:3 footage problem
  • Mixing 16:9 and 4:3 footage problem
    Posted by Peter Dewit on May 22, 2007 at 4:41 pm
    so I have a bunch of 16:9 anamoprhic footage in a sequecne in FCP. It is still stretched unletterboxed(anamorphic check is off). i was planning to export this as a 16:9 DVd through compressor. however now I found out i need to add a sequecne of images at the end. these pictures are full frame unstrecthed 4:3. The client would like the final product of these to come out pillerboxed on a LCD TV. They need ot be put on the same DVD as the other footage. any adivce on how to get this to work. I can’t letterbox the stuff that’s there now and I can’t let compressor squish the picutres either
    Peter Dewit replied 19 years, 4 months ago 5 Members · 6 Replies
  • David Roth weiss
    May 22, 2007 at 5:15 pm
    Peter,
    phew!!! That was a rather convoluted post… I’ll help you to sort this out.
    First things first… Is your video SD or HD? That makes a big difference because SD 16×9 requires the anamorphic checkbox to be checked in FCP, HD does not.
    David
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Bret Williams
    May 22, 2007 at 6:06 pm
    I think you work in a 16:9 sequence, with the footage checked as anamorphic. FCP will pillarbox and make adjustments to the SD 4:3, and will display the SD 16:9 correctly. I haven’t done a widescreen DVD but wouldn’t you mark the footage as 16:9 in DVDSP so that the player knows to either letterbox on a 4:3, or play 16:9 or a widescreen LCD?
    I’m sure someone will chime in on that.
  • David Roth weiss
    May 22, 2007 at 6:12 pm
    [Bret Williams] “a widescreen DVD but wouldn’t you mark the footage as 16:9 in DVDSP so that the player knows to either letterbox on a 4:3, or play 16:9 or a widescreen LCD?”
    Bret,
    That part is absolutely right, but its what Peter has on his timeline that needs to be sorted out first.
    David
    David Roth Weiss
    Los Angeles
  • Zak Mussig
    May 22, 2007 at 6:16 pm
    Hey Peter,
    At the end of the day you need the sequence of pictures to come after the anamorphic sequence on the DVD, not necessarily in your FCP timeline.
    Are the picture keyframed, or is it basically just a slideshow? If it’s a slideshow, just take the image files into DVDSP and set that up seperately. There’s a cool feature that can turn your slideshow into a video track once you get everything set up. I’m a big fan of this when I just have a few images I need to show in order with no user interaction on a DVD. It’s much easier than making a sequence for them in FCP then exporting to MPEG 2.
    If you need the pictures animated, then just set up a second 4×3 sequence in FCP and do whatever you like to the images there, then export 2 MPEG 2s… your sequence and your pictures. These files will be 16×9 and 4×3 respectively.
    DVDSP sets display settings at the track level, so set the video track to letterbox 16×9 and have it end jump to the 4×3 picture track. You’ll probably want to use some kind of transition either built into your videos or have DVDSP add a transition between the tracks.
    Hope that makes sense and takes care of your problem,
    Zak
  • Ron James
    May 23, 2007 at 12:55 am
    I’m guessing (from what I could understand) it’s just a matter of highlighting all those clips, then Remove Attributes > Distort.
  • Peter Dewit
    May 23, 2007 at 4:39 pm
    Thanks for all the replies sorry I wasn’t able to post again earlier. Sorry if it was confusing I had to type it pretty quick.
    Yes that is pretty much what I decided to do. Export the 4:3 pictures as seperate sequence and set them on a 4:3 track in DVDSP. Then on a LCD in 16:9 mode it should detect it’s 4:3 and simply pillar box correct? The way I exported the 16:9 sequence seemed to work ok. I put it on a 16:9 track in DVDSP and it was in the 16:9 aspect ratio looked great.
