Activity Forums Apple Final Cut Pro Legacy mixing 1440 with 1920
  • mixing 1440 with 1920
    Posted by Rob Gutermuth on June 29, 2015 at 1:54 pm
    Hi All,
    So I have a few multi cam shoots where 2 of the cameras are HD 1920x1080i and 2 are HDV 1440x1080i
    what is the best way to go, so that they are all the same in the timeline?
    Option 1:
    choose a 1920×1080 sequence which is native to 2 cameras, but the other 2 would have to be zoomed to like 137 percent or something to conform
    Option 2:
    Choose a 1440×1080 sequence, native to the HDV frame size, and then the aspect settings for the 1920 footage has to change to allow them to conform….
    I’m using option 2 right now, since that seems to look better than option 1, but is there a good option 3?
    Thanks all
    Rob Gutermuth
    Media Creations
    Daryl K davis replied 11 years, 2 months ago 4 Members · 4 Replies
  • Mark Suszko
    June 29, 2015 at 4:02 pm
    Yes, buy cameras that match next time:-) But your choice of option 2 is what most people do.
  • Rob Gutermuth
    June 29, 2015 at 4:37 pm
    Buy cameras that match…. lol. Yeah, that would be the best solution… but my money tree isn’t giving me anything lately 🙂
    I just read on here that 1440x1080i HDV is really 1920 anyways… True or not… some say yes, some say no… so, which is it?
    The seq didn’t have to re-render when I used Prores as the codec for the sequence (native clips, etc) – but the export takes 10x longer, and the file size is of course a lot bigger… and also it choose Square for the pixels…. HDV didn’t use that… does that matter?
    I guess my question is…
    would it be better to use the native 1440x1080i 60 HDV settings for the sequence, which matches perfectly with the main 2 cameras, and then force render the other 2, to I guess down convert from prores 1920x1080i 60
    or, just have the HDV footage in a prores sequence… what should all the setting be then, if I do that?
    not that it matters, but all cameras are set to NDF. My end result will be DVD mostly.
    Rob Gutermuth
    Media Creations
  • Michael Gissing
    June 30, 2015 at 4:56 am
    My advice is to chose option one. 1920 x 1080 is a proper frame standard and when you drop HDV 1440 in FCP automatically applies a 33.3% distort (not zoom).
    A 1440 x 1080 timeline means the 1920 gets squished and then on output everything stretched. Option one is correct and will require the least rendering.
  • Daryl K davis
    June 30, 2015 at 3:12 pm
    Yes, go full raster 1920 x 1080. You will not regret it.
    DK Davis / Editor/ Post Super
