Activity Forums Apple Final Cut Pro Legacy mixing 1080p and i
  • mixing 1080p and i
    Posted by Rob Alexander on April 16, 2008 at 9:00 am
    Apologies if this is a dumb question but it’s my first HD project and I haven’t even started it yet!
    My producer’s shooting 1080p 25 on HDCAM (F900) while another crew is shooting 1080i 50 again HDCAM (F750) and we’re going to use some of their footage. I’m planning to edit this in ProRes. Now I know that 25P isn’t true progressive, but will the two formats play together OK and what do I need to set my sequence settings to for a 25p master.
    Arnie Schlissel replied 18 years, 4 months ago 2 Members · 2 Replies
  • Rob Alexander
    April 16, 2008 at 1:04 pm
    small correction – going to master 50i so I guess the sequence will be 50i, however wise words about putting interlace material into a progressive sequence would be useful still.
  • Arnie Schlissel
    April 16, 2008 at 11:16 pm
    Technically, there’s no such thing as 1080P in HD Cam, it’s actually 1080PsF. If you digitize everything using the 1080 50i preset you should be fine.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
