Activity Forums DaVinci Resolve mixed TL conform, 5D and R3D
  • mixed TL conform, 5D and R3D
    Posted by Blase Theodore on November 18, 2010 at 6:54 am
    I’m trying to conform an EDL containing 5d and Red.
    • Transcoded and swapped 5D footage with uncompressed QT, and assigned unique numeric reel names.
    • used clipfinder to reconnect to r3d QT proxies, imported to FCP, and exported EDL from there
    If I conform with “assist using reel..”, “embedded”, I can get the red, but not the 5d QT media connected.
    If I conform with “assist using reel..”, “*source clip path /%R.mov”, I can get the 5d QT media, but not the Red connected.
    Any way to do a mixed timeline?
    Uli Plank replied 15 years, 10 months ago 3 Members · 6 Replies
  • Blase Theodore
    November 18, 2010 at 7:23 am
    My workaround was to use “embedded” reel names, and rename all the 5d reels to match their file names.
    So a clip MVI_1234 with source file name MVI_1234.mov got a reel name of MVI_1234.
    Not really a proper solution, but it works.
  • Uli Plank
    November 18, 2010 at 7:24 am
    Did you try QtChange (donationware) to assign TC and reel names to the 5D footage?
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
  • Blase Theodore
    November 18, 2010 at 7:33 am
    Thanks Uli. Was just looking for such a solution.
    However I would like to resolve the core issue as well. A non red workflow uses the %R.mov workflow to connect, and the red workflow uses a “reel name is file name” workflow.
    I’m bound to run into a feature later where they mixed regular QT footage with red footage. Then I’ll be stuck re-inputting all the QT file names as reel names for every clip. Seems using any r3d on the timeline locks you into that conform workflow.
  • Rohit Gupta
    November 18, 2010 at 7:37 am
    Try “*/%R.*” – this should work for both Red and 5D.
    Alternatively, you can set it for Red, add all the Red media. Then set it for 5D, and add all the 5D media to the media pool.
  • Blase Theodore
    November 18, 2010 at 7:51 am
    [Rohit Gupta] “Try “*/%R.*” – this should work for both Red and 5D.”
    Yeah I had tried that, but then nothing connected.
    [Rohit Gupta] “Alternatively, you can set it for Red, add all the Red media. Then set it for 5D, and add all the 5D media to the media pool.”
    Yes this works, and is the preferable solution. Thanks!
  • Uli Plank
    November 18, 2010 at 11:47 am
    Great workaround, thanks!
