Activity › Forums › Apple Final Cut Pro Legacy › Mixed res in timeline
Posted by Videobiker on July 26, 2005 at 1:11 pmWhen mixing resolutions in the timeline(Betacam, DV, VHS Composite)must you always render the video that does not match your timeline settings? Am I doing something wrong?
Biker
Videobiker replied 21 years, 1 month ago 3 Members · 4 Replies -
David Bogie
July 26, 2005 at 2:22 pmYes.
Clearly explained in the manuals.bogiesan
Videobiker
July 26, 2005 at 4:49 pmI looked under the index for “mixed resolutions” and under the timeline options but have not been able to find the info. Can you guide me to which book (1-4) and chapter? Would greatly appreciate it.
Biker
Bob O’brien
July 27, 2005 at 12:20 amHi Videobiker.
Unless there is something new in FCP I don’t know about, you have NEVER been able to mix resolutions in a FCP timeline. If you do, yes, it has to be rendered.
If all of your clips are alreadsy captured, the only way around this is to export all your clips to a common format and use that setting as your sequence setting. Of course, ideally, you would have captured each clip through you Kona card to a common compression format.
Hope this helps.
Bobo
Videobiker
July 27, 2005 at 2:07 amThanks Bobo,
I got that info earlier. I guess I have to do all my rough in DV and then res up the final show and render out the video bedore going to tape.
Thanks for the help.
Biker
