Activity Forums Event Videographers Mixed light
  • Mixed light
    Posted by Cow_fan on November 21, 2006 at 10:30 am
    Me and my consumer camcorder are always in a situation of mixed lighting. I shoot my daughter in her classroom with light from the window and fluorescent lights, some friends in a house with mixed fluorescent and incandescents, etc. what will I do to get a perfect white balance in these situations? Thanks.
    Cow_fan replied 19 years, 10 months ago 3 Members · 4 Replies
  • Thaxter Clavemarlton
    November 21, 2006 at 10:43 am
    You can’t get “perfect” WB in a scene where you have multiple light sources and no control of them.
    The compromise is “auto WB” but the constant changing is annoying, as well.
    Manually WB in the area that will have the most “focus” in your shoot and live with it.
  • Cow_fan
    November 21, 2006 at 1:05 pm
    Thanks Thax. I’ll do that. I thought before that there’s some magic, no-compromise solution to this problem.
  • Mark Suszko
    November 21, 2006 at 4:46 pm
    Keep the windows behind you, for one thing. If you balance for daylight, tungsten sources will be red or ruddy, but this “warm” look is more pleasurable than nalancing for tungsten where there’s a lot of blue daylight coming in and making people look pale and sickly. And flourescent makes everybody look green. The compromise is to balance to the dominant light in the shot, whatever that is, and make the best of the off-color sources by shooting around them. Sometimes you can override a blue or green room if you bounce a big enough halogen light off the ceiling or a big white wall nearby. But in many situations you may not be able to do that. Some folks like to use a white card to fool the camea by reflecting part of the daylight and part of the incadescent. This works sometimes but I don’t do it too often.
    I continue to be astounded by the improvements in “shockless” automatically-adjusting white balance in modern cameras, but they do best when presented with one choice of temp at a time, so don’t put the windows and the practicals in the same shot and you will do better.
  • Cow_fan
    November 22, 2006 at 6:52 am
    Thanks Thax!
