Activity Forums Apple Final Cut Pro Legacy Mixed Frame Sizes sequence
  • Mixed Frame Sizes sequence
    Posted by Maria-luisa Meredith on February 28, 2013 at 7:37 pm
    Hi
    I’ve been given footage shot with two different camera’s, though I will be editing them into one sequence.
    I realise I can render in FCP so that either will play in the others sequence set up, but wondered if there is a quicker way to convert, and if so which way (1440 footage to 1024 or vice versa)?
    The files are:
    HDV / 1440×1080 50i / 25fps (originally MTS files converting using ClipWrap)
    and
    H264 / 1024×576 / 25fps
    Thanks as always,
    M
    Macbook Pro / OSX 10.6.4 / 2.4GHz Intel Core i5 / 4GB 1067 MHz DDR3
    FCP Studio 7.0.2
    Maria-luisa Meredith replied 13 years, 6 months ago 2 Members · 2 Replies
  • Mark Suszko
    February 28, 2013 at 8:33 pm
    Well, FCP 7 can edit the HDV all right natively, but it cannot do that for H.264, so for speed’s sake, I would convert the h.264 to match your other HDV camera, or make a sequence in pro res and convert both cameras to that.
  • Maria-luisa Meredith
    February 28, 2013 at 8:41 pm
    Ah, excellent. Thank you very much for your reply, just wanted to be sure which way to go with it all.
    M
    FCP Studio 7.0.2
