Activity › Forums › Apple Final Cut Pro Legacy › mixed frame size/codec
Posted by Gerret Warner on May 30, 2010 at 6:46 pmI need to intercut footage in 1080/60i ProRes and P2 footage shot in 720/24. What’s the best timeline codec to use so I maintain quality and minimize rendering time? (I don’t know yet which source will be used most).
GW
Gerret Warner replied 15 years, 11 months ago 3 Members · 4 Replies -
John Fishback
May 30, 2010 at 8:03 pmIs the P2 footage 24PN or 24 over 60i?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
John Heagy
May 30, 2010 at 10:01 pmI would go with a 1080i60 ProRes timeline, but you shouldn’t drop your 720p24 onto it, as FCP will not add 3:2 pulldown – it does 4:2 – repeating every 4th frame.
You would need to up rez the 720 to 1080 and frame rate convert 24 to 60i by adding 3:2… there are a few tools to do this. The Nattress Standards conversion FCP plug in will do this on the timeline, but that may be a bit slow to edit with depending on how much you have. If you do have a lot of 24p, I would opt to process it all first. The trick will be maintaining TC 24 to 30… if that’s important. I haven’t used Nattress much, but you may be able to add the filter to all the 24p clips in the Bin and batch export.
Alternatives would be JES deinterlacer (free), After Effects or Episode Pro. The two latter will not maintain TC, not sure about JES. Compressor can do it but finding the correct combo of settings is tricky as there is no “Add 3:2” setting, it just happens if the settings are a certain way. I really hate Compressor’s interface.
If all your 24p is contained in a segment of it’s own, you could edit in 720p24N then do the conversion to the finished segment, and drop in on the 1080i timeline to finish with the 1080i footage.
Just curious… what came first the 1080i or the 24p?
John Heagy
Gerret Warner
May 31, 2010 at 3:24 pmThanks for taking the time to analyze the issue.
The P2720/24PN came first and is the look I’d prefer to maintain–better camera, better color, etc.
According to Graeme Nattress “Standards Converter with G Film Converter, NTSC to Film option” will convert the 1080i footage to 24.
If I do as planned, maintaining 24, the question is whether to edit on a 720 or 1080-size frame, and which ProRes codec to use. (I have Video Purifier which claims to be the best choice for changing frame size).
The final output will be on a large screen.
Thanks again
GW
