Activity Forums VEGAS Pro Mixed fps and Shutter settings.
  • Mixed fps and Shutter settings.
    Posted by Martin Phillips on July 28, 2017 at 7:08 pm
    Hi, I have a project with mixed footage. Some shot at 50fps, 100 Shutter, and other at 25fps , 50 Shutter. My question is for the best results what project and render settings should I use? The final project will go to Vimeo and possibly bluray. Regards Martin
    John Rofrano replied 8 years, 9 months ago 2 Members · 1 Reply
  • John Rofrano
    August 1, 2017 at 11:54 am
    [Martin Phillips] “My question is for the best results what project and render settings should I use? The final project will go to Vimeo and possibly bluray.”
    You will want progressive video for Vimeo and interlaced video for Blu-Ray. I would render 1080-25p for Vimeo and 1080-50i for Blue-Ray. You could actually use the 1080-25p on Blu-Ray as well (it will interface for you) so if you only want to render one format, I would go with 1080-25p.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
