Activity › Forums › Adobe Premiere Pro › Mixed formats and hanging macbook
  • Mixed formats and hanging macbook
    Posted by Ben Cooper on August 24, 2014 at 2:12 pm
    Hi
    Thanks for looking…
    CS5
    2009 Macbook pro
    10.6.8
    2.66GHz core 2 duo
    I have around 6hrs of footage to cut down to an hour and a half. It’s mpeg and mov from a canon 60D and XHA1.
    I think where I went wrong was synching all the footage on a timeline and doing some zooming and rotating to correct shots and a bit of colour correction as I went along editing. So the project ballooned in size and began hanging and crashing premiere pro. I’ve now split it up into two projects and 6 sequences and it is opening and running fine again.
    So, I was thinking I would export each sequence and then put them all back together on one timeline for a final export for encore and internet.
    Is this a good plan, if so, would I be losing quality to export as H.264 and then import back in to the final project. I think if I export massive mov files this macbook won’t handle it or will take forever?
    Excuse the ignorance please, any hel would be greatly appreciated.
    Ben Cooper replied 12 years ago 2 Members · 2 Replies
  • Chris Tompkins
    August 27, 2014 at 9:55 pm
    Your system is aging and this project could be taxing it’s resources.
    You do NOT want to got to .h264 for the cross hop. This is more of a delivery codec, sometimes acquisition.
    Can you import just that one sequence into the other project? I don’t recall if that works with CS5.
    Chris
  • Ben Cooper
    September 1, 2014 at 12:02 pm
    Hi
    Thanks very much for your reply.
    I can just copy all the separate sequences into one sequence at the end I think, yeah.
    But I thought that might just put me back to having a huge project problem again and it jamming up.
    Good to know about the H.264 though thanks. I definitely won’t do that. I’ll carry on with the edit and then copy to one sequence once it’s all done.
    Thank you
