Activity › Forums › Apple Final Cut Pro Legacy › Mixed formats and frame sizes
Posted by Steve Rogalinski on February 25, 2011 at 4:27 pmwhen you have mixed formats in fcp is it better to base the sequence on the highest or lowest quality clip?
Steve Rogalinski
Jeff Greenberg replied 15 years, 6 months ago 2 Members · 3 Replies -
Jeff Greenberg
February 25, 2011 at 4:31 pmSteve,
I suggest that the best choice may be:
•One that matches your output needs (if you’re mixing HD & SD, and the result is SD to the web…SD all the way)
•One that matches where most of your format sourced (XDCam + DVCProHD where 90% is XDCAM).It really really depends on the type of footage your mixing and what you’re doing with it at the end…..
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com -
Steve Rogalinski
February 26, 2011 at 3:16 amThanks for your help. What if I’m mixing HD and SD with an HD output?
Steve Rogalinski
Jeff Greenberg
February 26, 2011 at 4:14 pmProbably best to work in HD and upscale the SD. Frame rate changes are harder for FCP than scaling (although you should make sure you change your sequence settings for highest quality for scaling.)
Best,
Jeff G
