Activity Forums Apple Final Cut Pro Legacy Mixed Format Workflow – SD & HD
  • Mixed Format Workflow – SD & HD
    Posted by Sascha Engel on May 29, 2011 at 2:16 pm
    Hi Everybody,
    I am currently editing a Mocumentary, which consists of DV-PAL SD Footage 25p from a Panasonic DVX100B mixed with Footage from a small HD Consumer Camcoder (Files been given to me, transcoded into Apple ProRes HQ) and Foptage of the GoPro mini HD Cam (currently imprted as MP4s).
    Now my Qs:
    1. Into what should I convert my GoPro Footage to (is connected with Q 2:)
    2. What is the best Timeline Format to edit my project in? Making a Timeline according to the SD 25p Footage of the DVX100B and downsizing the ProRes HD clips when I through them in, or is that a shame, when CC, better to use the HD footage in native size?
    3. When converting the GoPro Footage into e.g. Apple ProRes, is Episode a good App to go and Batch them all through there?
    Thanx a lot.
    Sascha
    Sascha Engel replied 14 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    May 29, 2011 at 6:27 pm
    [Sascha Engel] “1. Into what should I convert my GoPro Footage to (is connected with Q 2:)”
    ProRes. YOu have been hanging out here long enough to know that by now Sasha… 🙂
    [Sascha Engel] “2. What is the best Timeline Format to edit my project in?”
    What does the MAJORITY of your footage consist of? What is your final deliverable going to be?
    [Sascha Engel] “3. When converting the GoPro Footage into e.g. Apple ProRes, is Episode a good App to go and Batch them all through there?”
    Compressor batches…
    Shane
  • Sascha Engel
    May 29, 2011 at 7:27 pm
    HI Shane,
    yes, you are right, I thought already ProRes, but I never worked with GoPro footage before – and wanted to be sure.
    The Material is for 60% SD DV-PAL Footage and 40% GoPro and ProRes Converted Footage from a Consumer HD Camera.
    I know, that Compressor had a Batch Capture, but I just read a lot about Speed & Quality issues in Comparison to e.g. EPISODE – tried Episode on a friend’s machine and I was blown away – the speed difference is mind blowing. EPISODE versus Compressor is like Ferrari versus VW Beatle!
    Greetz,
    Sascha
  • Sascha Engel
    May 29, 2011 at 7:28 pm
    …ah and final output:
    Projection on a big screen during a theatre show – most likely from a computer or DVD Player.
    Sascha
  • Shane Ross
    May 29, 2011 at 8:03 pm
    Well, unless you can upconvert the SD to HD via hardware I’d stick with SD. But not DV. Prores Pal or DV50
    Shane
  • Sascha Engel
    May 29, 2011 at 8:54 pm
    Hi Shane, thanx a lot. DV ProRes it is.
    Sascha
  • Michael Gissing
    May 29, 2011 at 11:08 pm
    Stick with a ProRes timeline, not DV50. That way all your material including the converted DV to ProRes footage should all be upper field. A Dv50 timeline will mean lower field sequence with upper field footage which is a total pain.
  • Sascha Engel
    May 30, 2011 at 3:23 am
    I think, that wouldn’t be a problem, since it’s all 25p footage, no interlaced material at all.
    Sascha
