Activity Forums Apple Final Cut Pro Legacy mixed format show question
  • Matthew Nelson
    January 11, 2008 at 1:23 am
    At some point you’ll have to down convert the HDV. Have you dropped the HDV footage directly into a SD sequence? If the rendered footage is expectable to you and your client, problem solved. But at some point you’ll have to DC the HD to SD. For efficiency sake doing it upfront would be best.
