Activity › Forums › Adobe After Effects › Mixed footage rendering problemsf
Posted by Videonow on March 6, 2007 at 2:25 pmIm importing HD files from aspect HD into 720×480 comp with regular avi files. The Aspect HD files are greenscreen with keylight effect. When I render out comp, there are many frames that seem to appear out of nowhere. For instance, I have interview subject keyed, with B-Roll in background. Often frames of the B-Roll will show clips from the interview footage.
Any suggestions to remedy this problem?
Chris @ ReachFreq
Hahaiah replied 19 years, 6 months ago 5 Members · 7 Replies -
Mylenium
March 6, 2007 at 5:29 pmDon’t use AVIs. ;O) Your problems seem to be specific to the CoDec you are using. It doesn’t seem to handle the Alpha properly, probably because it uses some compression and pixels from the YUV/ RGB cchannels don’t line up with the Alpha.
Mylenium
[Pour Myl
Videonow
March 6, 2007 at 5:34 pmThanks for the info Mylenium.
In the interum I think I’ve solved the problem another way:
In my first attempts, I didn’t pre render any of the comps that were included in my final comp. I am currently pre-rendering them and thus far has seemed to fix the problem.
Thanks again
Chris @ ReachFreq
Kevin Camp
March 6, 2007 at 5:44 pmonce i had experience similar to yours, random frames showing up in a render… i think it was ae5.5 or 6.5 on a mdd g4. it was like random frames were getting stuck in ram and showing up in a project’s render that wasn’t even using those frames.
i was able to edit>purge>all to fix. but i’ve never had that problem since.
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Sam Moulton
March 6, 2007 at 5:46 pmsounds like a frame rate and fields problem
check your interpretation, double the frame rate of the comp and check fields there
Videonow
March 6, 2007 at 5:48 pmThat seems like it would be a preferable solution to pre-rendering everything. Less time consuming especially for the ongoing project I am working on. I will give it a try.
Thanks Kevin
Chris @ ReachFreq
Videonow
March 6, 2007 at 5:50 pmCould the root of the problem be that the Cineform files are UFF, while the AVI’s are LFF and the render selection I made is LFF?
If so, how is the best way to handle fields in a comp where some of the files are UFF while others are LLF?
Chris @ ReachFreq
Hahaiah
March 15, 2007 at 10:44 pmI also have alot of problems using Cineform Aspect HD.
Using cineform’s capture tool or Adobe gives me trouble.Oddly, when I first begin a comp, everything seems to work fine, but towards the end after all the work is done, I get frames showing up at random that seem to come from a variety of cineform files in the comp.
After checking the files frame by frame in other apps, they don’t show any flaws.
I’ve gotten the same effect on three different systems.
I usually use Virtualdub to simply recompress with the same footage and still choose the cineform codec. Files processed with Vdub don’t seem to have any of the above troubles.
