Activity › Forums › Apple Final Cut Pro Legacy › Mixed Fields Footage
  • Mixed Fields Footage
    Posted by Joseph Wilkins on January 10, 2008 at 11:43 pm
    Hello… I have multiple clips shot in HD, SD and animations created in After Effects. Some are progressive, some have upper fields first, some lower… How should I create my FCP comp to handle them all correctly? I have tried going to their properties and changing them to upper, lower within final cut, but cannot get them to loo right… I have flicering fields all over…
    Please could someone step me through this problem… Many thanks
    Jeremy Garchow replied 18 years, 8 months ago 6 Members · 13 Replies
  • 13 Replies
  • Jeremy Garchow
    January 11, 2008 at 12:26 am
    What format is your timeline?
  • Joseph Wilkins
    January 11, 2008 at 12:29 am
    Well, I’ve messed around with a few, but I settled on basic NTSC DV, with fields set to NONE
  • Joseph Wilkins
    January 11, 2008 at 12:39 am
    OK… so I know what you wouldn’t do.. can you tell me what you would do?
  • Paul Escandon
    January 11, 2008 at 12:45 am
    Is one of those formats a dominant format that most of your footage is in? Or is there an equal mix of HD, SD, different field patterns, and after effects movies?
    Also, what kind of a project is it and what is your intended output? Is this going to broadcast or just getting burned on a DVD? This info would be helpful in helping you.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Joseph Wilkins
    January 11, 2008 at 12:51 am
    It’s pretty even spread NTSC DV footage and DVC PRO HD.
    It’s my demo reel and intended output is a flash video file for my website AND a DVD for handout
  • Paul Escandon
    January 11, 2008 at 1:00 am
    Well if that’s the case then I’d see no reason why setting up an NTSC DV timeline would be a problem whatsoever. You might want to try the setting you had with the fields set to none, and also give it a shot with a field setting turned on (say.. lower). I’d do a test DVD burn of both and see what looks better to you.
    Paul Escandon
    Oremus Productions
  • Joseph Wilkins
    January 11, 2008 at 1:03 am
    Yeah… that’s the problem.. the beautiful graphics I created in AE in HD format now look blocky in Final Cut’s Preview window. Is there a SD format that is lossless I should work in to avoid this artifacting.. maybe I what I was thinking was a fields issue is really a compression artifacting issue… any help?
  • Matthew Nelson
    January 11, 2008 at 1:04 am
    If time is of the essence I’d just deinterlace the problem clips.
  • Matthew Nelson
    January 11, 2008 at 1:27 am
    Are the blocky graphics fully rendered at best quality? Have you tried taking these graphics back into AE and rendering out a SD version?
  • Michael Sacci
    January 11, 2008 at 10:22 am
    I would stop fighting it in FCP and take everything to compressor. I would convert everything to a common codec like SD Pro Res, DVCPro50 or 10-bit Uncompressed. The DV footage will not benefit from this but the animation and the HD footage will compress a lot better when you go to DVD.
    Compressor 3 does a great job with reordering field.
