  • Posted by Donato M. rondinelli on January 25, 2006 at 12:03 am
    I have a few audio questions:
    a)Is it OK to mix 44 & 48K audio clips in the same timeline?
    b)Can I mix 48K 16bit & 48K 24bit in the same timeline?
    c)How does 24bit audio get created? My Kona LH & FCP sequence are both set to 16. My sources are analog & digital(AES) audio.
    Thanks!!
    -dMR
    Donato M. rondinelli replied 20 years, 7 months ago 2 Members · 2 Replies
  • Will Salley
    January 25, 2006 at 5:28 am
    Yes, it is possible to mix 44k and 48k clips in the same timeline.
    Yes, it is possible to mix 24-bit and 16-bit clips in the same timeline.
    24-bit audio comes from the same place that 16-bit comes from, just with different settings, hopefully set at the beginning of a recording session.
    You can do it too! Open an audio file with QT Pro. Select File>Export> and then, under options, select the bit rate from the pulldown.
  • Donato M. rondinelli
    January 25, 2006 at 7:28 pm
    Thanks. What about a blue line on top of my audio clip? I heard that it’s bad.
    -dMR
