Mixed 29.97 & 23.97 Pro Help !
Hi everyone,,
I have 6 movie clips of which 4 are 23.97 & 2 are 29.97
I have a movie project comp that has 6 clips. The first clip is shot at 29.97 frames, the 2nd,3rd & 4th are 23.97 frames. and the last clip is 29.97. see my problem?
All clips have to be motion tracked. I’m afraid that mixing the two frame rates on 1 project setting are going to screw up my motion tracks. What is the best way to correct this?
For example, Do I make a project @ 29 frames and put the 2 clips (29.97) in it.
Then, motion track it & past it into the other project file of 23.97 and render it out?
If I do, isn’t that the same thing as leaving them all on one project comp? Doesn’t the pasted comp now run slower on the 23 frame comp? I am so confused!!!What would you do? …and don’t say…. “I would have shot everything in 23.976.”
I know, I know.. I screwed up, I shot “behind the scenes” footage while they where filming and the director liked my 2 shot angles better than his footage. So now I have Mixed frame rates!
Lou
