Activity › Forums › Avid Media Composer › mixdown media offline
  • mixdown media offline
    Posted by Sonya Dudnik on December 29, 2016 at 4:52 pm
    Hello guys,
    really need your help here.
    I have a problem with several mixdowns gone media offline, after being accidentally rendered on external hard drive which is since dead. is there any way to know which exact clips were used for those video mixdowns? they were in complex compositing plans with lots of effects (I used to mixdown to gain time for timewarping after using 3d warp, luma key, flopping etc) hope there is an easy way for at make Avid point at those exact clips to re-do the compositing… match frame obviously doesn’t work. panics!!!
    Shane Ross replied 9 years, 8 months ago 3 Members · 2 Replies
  • Glenn Sakatch
    December 29, 2016 at 5:15 pm
    sorry, you are going to have to rebuild the original the hard way. I usually save a pre mixdown sequence if i do anything like that, just in case this happens.
    You could check out your attic and see if an older version of the sequence exists (pre mixdown) and re do the section in question.
    Glenn
  • Shane Ross
    December 29, 2016 at 6:40 pm
    Sorry, but unless you layered those mixdowns on top of the footage, there is no way of knowing what they were made of. They are simply video files…no data links them to the clips they were made from.
    Video Mixdowns are VERY dangerous, and you see why. You can’t match back to the sources, and if you lose them, they are gone. No way to re-create them unless you layer them on top of the videos you made them from. Online really doesn’t like Video mixdowns…by the way.
    If you have to do them, for compositing and effects reasons, then you need to keep the sections they were made from, either on the timeline, or as separate sequences. And you need to render them out very high resolution…and what they are made FROM should also be high resolution. Mixdown comps should not be made when cutting in an offline resolution. Recreating what was done might be very tricky to duplicate after you bring the footage to full res.
    Sorry…now you see why this is discouraged. I only use them when temping what I want Graphics to recreate, or when exporting for one reason or another.
    Shane
    Little Frog Post
