Activity Forums Apple Final Cut Pro Legacy Mix Hd(progressive), HDV(upper field) and Dv(low field) in the same timeline in FCP for then output to tape?
  • Mix Hd(progressive), HDV(upper field) and Dv(low field) in the same timeline in FCP for then output to tape?
    Posted by Julio Cesar on June 1, 2012 at 3:09 pm
    Please, can some one tell the way to work with this 3 diferent type of media, i need to know what i need to do to have a clean and a very good looking video for output to tape for broadcast, so i dont want to se jagged video or someting or ghosting, i really need help here to deliver a good video. Thanks.
    Julio Cesar replied 14 years, 3 months ago 2 Members · 2 Replies
  • Shane Ross
    June 1, 2012 at 4:40 pm
    Use a ProRes timeline. Set the field dominance to “None.”
    If you have multiple frame rates, convert the ones that don’t match the main frame rate.
    Shane
    Little Frog Post
  • Julio Cesar
    June 1, 2012 at 5:22 pm
    No, my videos are at the same frame rate, so thats not a problem, i tink the problem can be the dominance field, and my delivery format is to tape.
    So the only problem that i have is the that the progresive HD and the interlaced HDV seems to have some problems with the fields, the DV footage look right, because i use a timelien of 720×480 and the dominance field to lower even.
    So my cuestion here is, with the ProRes timeline i wouldnt have problems with the field? remember that my output is to MiniDv for Broadcast. Thanks
