Activity › Forums › Apple Final Cut Pro Legacy › Mix format Editing (H.264 & DVCPRO HD (720p60)
  • Mix format Editing (H.264 & DVCPRO HD (720p60)
    Posted by Elaine Lee on January 13, 2011 at 7:37 pm
    I have shot some footage in the below formats to be edited together using FCP6. I’m not sure what is the best workflow for this. In order to ensure smooth edit and similar aspect ratio in the final product
    Main camera:HVX200
    Dimension: 960×720
    Codecs: DVCPRO HD (720p60), Integer (Little Endian)
    B-Rolls-Nikon D7000:
    Dimension: 1280×720
    Codecs: H.264, Integer (Little Endian)
    Should I convert both footages into ProRes in Compressor before editing them?
    I’ve tried converting the H.264 footage to DVCPro HD. However, every time I try to edit the converted footage, my computer freezes and crash.
    Brian Deviteri replied 15 years, 8 months ago 4 Members · 3 Replies
  • Rob Grauert
    January 13, 2011 at 7:49 pm
    That’s strange that the DVCPro HD files converted from H.264 cause your computer to crash. The only thing I can think of that MIGHT confuse your computer is transcoding to DVCPro HD at 1280X720 instead of 960X720 with the correct pixel aspect ratio.
    Anyway, whenever I transcode Long GOP video, such as H.264, to something editable, I convert to ProRes 422. Then I’d work in a ProRes 422 timeline. No need to convert your DVCProHD footage to ProRes though.
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Thomas Morter-laing
    January 13, 2011 at 9:15 pm
    Personally I’d transcode everything to prores 422, even the DVCProHD stuff- yes it’s an ok editing format, but may as well batch transcode overnight everything to minimise rendering etc
    Tom Morter-Laing
    Freelance Editor
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
  • Brian Deviteri
    January 20, 2011 at 10:05 pm
    Thomas – I’d recommend the same for the best performance and less of a headache later on, especially if any of the source media will also be used by another application (like After Effects) down the road.
