Activity › Forums › Blackmagic Design › Mix dv and 8-bit
  • Mix dv and 8-bit
    Posted by Wolf on June 21, 2006 at 9:39 am
    Hello,
    when i mix two clips: first captured with decklink 5.6 PAL dv codec
    2. with 8 bit PAL and apply by example a dissolve between those clips
    the reuslt “skips” down by one or two line of the 720.
    Also i want to caputre clips in PAL DV Decklink Codec and render the
    effekt with 8-bit for a better quality, no way…it also skips down.
    Does anybody have a workaround to mix those two codecs in a timeline!
    thanks
    Claus-Peter Wolf
    Wolf replied 20 years, 3 months ago 2 Members · 2 Replies
  • Baz Leffler
    June 22, 2006 at 12:30 am
    My workaround is to apply a null filter to the incoming/outgoing DV clips to force render. I normally use ‘brightness/contrast’ set to zero.
    Baz
  • Wolf
    June 22, 2006 at 9:02 pm
    That
