Activity Forums Compression Techniques Mix 2 Mono Audio Stream in 1 Stereo Stream
  • Mix 2 Mono Audio Stream in 1 Stereo Stream
    Posted by Lormeau Bertrand on April 15, 2010 at 2:30 pm
    I search to convert GXF file to DVPRO50.
    I use this command :
    ffmpeg -i test.gxf -deinterlace -target dv50 testdv50.dv
    I obtain this result:
    Input #0, gxf, from ‘test.gxf’:
    Duration: 00:00:47.36, start: 4770.000000, bitrate: 21225 kb/s
    Stream #0.0: Video: mpeg2video, yuv422p, 720×576 [PAR 16:15 DAR 4:3], 18000
    kb/s, 50 fps, 25 tbr, 50 tbn, 50 tbc
    Stream #0.1: Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
    Stream #0.2: Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
    Stream #0.3: Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
    Stream #0.4: Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
    Stream #0.5: Data: 0x0000
    Assuming PAL for target.
    Output #0, dv, to ‘testdv50.dv’:
    Metadata:
    encoder : Lavf52.54.0
    Stream #0.0: Video: dvvideo, yuv422p, 720×576 [PAR 16:15 DAR 4:3], q=2-31, 2
    00 kb/s, 90k tbn, 25 tbc
    Stream #0.1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #0.1 -> #0.1
    Press [q] to stop encoding
    It is possible to obtain this result ?
    Metadata:
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #0.1 -> #0.1 Left
    Stream #0.2 -> #0.1 right
    It’s possible to add in sigle audio stream the stream #0.1 ( on the left ) and the stream #0.2 ( on the right )?
    thank you for your help !!
    BobTheChinese
    Alex Nesterov replied 14 years, 7 months ago 3 Members · 3 Replies
  • Michael Rampe
    April 16, 2010 at 9:29 am
    Merging two mono streams into a left/right panned single stream….
    short answer is: not yet;-)
    I found this task on the google summer of code wiki related to ffmpeg:
    Implement negotiation of sample format and number of channels analogously to the libavfilter colorspace negotiation
    * Does this imply a channel mixing filter? This would be the second most desirable basic audio filter in my opinion.
    https://wiki.multimedia.cx/index.php?title=FFmpeg_Summer_Of_Code_2010
    As this states, this is a work in progress and a very much needed feature.
    My question for you is: what are you trying to do with the output file?
    If you intend to edit it in a NLE later, you CAN map two streams to two new streams. They will both be mono but will be separate tracks which will work in an NLE. I recreated a 4channel movie to test with similar in stream layout to your .gxf file. I then used this command line to map audio channel 1 and 2 to two new streams in the output file.
    ffmpeg -i input.mov -map 0:0 -map 0:1 -map 0:2 -vcodec dvvideo -s 720×576 -aspect 5:4 -acodec copy output.mov -acodec copy -newaudio
    This came into my NLE (Final Cut Pro) as two center panned mono tracks. It is then simple to pan them left and right respectively in the NLE. NOTE: I could not get it working with the .dv wrappper or -target dv50 settings which is why I set the codec/size/aspect myself.
    Finally, from the research I have done, mencoder (another free command line tool) DOES have a pan function so you may want to investigate that.
    Michael
    “half-way to world domination A.K.A. the belligerent blue bike shed”
  • Lormeau Bertrand
    April 19, 2010 at 11:18 am
    Mickael,
    Thank you for your reply.
    I’m looking to convert GXF files in TS H264/AAC.
    For this I use Carbon Coder which has a channel mixing, but i have problems with the de-interlacing filter.
    So I’m looking for another way to get a better result.
    That’s why I wanted to convert GXF files in DV50 files for testing the ffmpeg de-interlacing filter. ( The result is not better 🙁 )
    It is at this moment that I discovered that ffmpeg did not allow to select multiple single stream for make a stereo stream.
    FFmpeg take the first stream mono and duplicate it in a stereo stream.
    I’ll try mencoder, and the yadif filter.
    I hope he will accept GXF files in source.
    I tried your command line, but it does not work with the GXF and dv.
    Respectfully
    BobTheChinese
  • Alex Nesterov
    January 12, 2012 at 10:33 pm
    Hi Michael!
    Sorry I’m not an ffmpeg expert and not intend to be.
    Everything works perfectly- i just want to send mic mono input to both channels out. Like normally programs do on default.
    It’s crazy: in my stupid project having 3 not so bad computers -including mac and windows- only ffmpeg does the job.
    Here is the command which works great- I just don’t know how.
    ffmpeg -f oss -i /dev/audio3 -f video4linux2 -s 320×240 -i /dev/video1 out.mpg
    Thank You in advance!
    I simply don’t know how to write the script. Sorry.
