Activity › Forums › Apple Motion › Missing Z-axis rotation
  • Missing Z-axis rotation
    Posted by Pj Palomaki on February 4, 2010 at 12:55 pm
    Any idea why a shape exported from Illustrator as a Motion Shape (via Export as Motion shape script) lacks Z-axis rotation when brought to Motion? X and Y axis can be rotated but there isn’t Z axis available. Is this a bug in the export script or am I just missing something?
    The object has no filters or behaviours applied.
    See picture…
    Lukas Gähwiler replied 13 years, 10 months ago 4 Members · 3 Replies
  • Mark Spencer
    February 4, 2010 at 2:12 pm
    That’s very odd – can you rotate it on the z-axis in the Inspector – IOW, is there a handle sticking out of the anchor point?
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Scott Hyldahl
    May 27, 2011 at 7:19 pm
    I’m having the exact same problem and have always been when using the Illustrator script. There is a handle coming out of the anchor point of the shape, but if I want to use parameters on the z-rotation, I’m out of luck because z-rotation doesn’t show up in the inspector. The only way I can seem to animate the z-rotation is by using the record button and manually rotating it with the handle. Anybody have any further insights into this?
  • Lukas Gähwiler
    November 16, 2012 at 1:52 pm
    same problem also here: no z-axis on illustrator-scripted shapes.
    I create a clone of the shape and then you have a z-axis on the clone…
