Activity › Forums › Apple Final Cut Pro › Missing Titles and Generators in FCPX
  • Missing Titles and Generators in FCPX
    Posted by Brendan Kelsey on June 23, 2016 at 7:48 pm
    Hey all,
    I was wondering if anyone could help me figure this out. I have a project with all of the original media stored in the FCPX library on an external hard drive. I used Motion 5 to create a generator and a title for this project. Everything was great until I had to sell that computer and upgrade to a newer one. I knew the generator and title needed to not only be in the motion templates folder, but have the same filename and be put in the same folder. So on the new computer, I located the same folders and I copied the files in place. So I believe everything is where it should be and titled appropriately. For some reason when I open FCPX all of those generators and titles are missing with no way to relink them or see the file chain. What’s weird is I can see them in the effects library. Does anyone have any ideas? Thanks in advance!
    Patrick Bory replied 4 years, 11 months ago 9 Members · 12 Replies
  • 12 Replies
  • Andreas Kiel
    June 24, 2016 at 8:18 am
    There is a kind of common problem creating “Template Paths” manually.
    In Finder a path a) like “~/Movies/Motion Templates/Titles/myTitle” and a path b) like “~/Movies/Motion Templates/Titles/myTitle” obviously look like the same.
    If you have a detailed view (for example pressing cmd-I) you will see the difference.
    Path a): “~/Movies/Motion Templates/Titles/myTitle”
    Path b) “~/Movies/Motion Templates.localized/Titles.localized/myTitle”
    Path b) is be the correct one.
    Final Cut needs “/Motion Templates.localized/TemplateTypea.localized/” path (i.e. the ‘.localized’ extension).
    So check the paths you created.
    -Andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
  • Chris Faber
    November 25, 2017 at 5:55 am
    I’ve got this issue. I’d love to know if anybody’s found a solution to this — other than editing an xml. Perhaps a third party program?
    If not, Andreas could you share more details on how to edit the xml to point titles in the timeline to the new locations. I got myself into this because I wanted to re-organize more logically where my custom titles resided. I did this externally (because there is no way to do it internally as far as I could see.). Now in the browser things are well organized. And all titles in all timelines that use my custom lower thirds are offline.
    If I understand correctly, I can export the timeline xml, find those titles in the text and somehow rewrite to tell it where to find the right ones?
    I’d love to see a sample of the code change in an xml.
    Chris Faber
    Faber Productions
    faberproductions.com
  • Bill Davis
    November 25, 2017 at 5:24 pm
    THIS is why many of us recommend against doing organizational work in the finder rather than just allowing the database in X to track the locations of assets as it was designed.
    As MacOS continues to evolve with more virtualization, more security, more network interconnections, this “where’s the file” game is going to get harder and harder to manage manually.
    I certainly understand the allure of the old “folder culture.” and spent decades in it as well – but after 6 years of X, (and as a non-networked editor) I literally am down to ONE root desktop level folder per Library as a container to house all my imported graphics and similar digital assets.
    Then as long as I scrupulously download to – import from – THERE – I can just let X manage ALL the location arrangements.
    If I need to go back and recover projects off deep storage – dragging that one folder back onto the desktop (root) fixes ALL the database location links automatically.
    The ability to essentially ignore finder locations has been a HUGE time saver for me.
    And even better, if after the project it put to bed – I can make that folder part of an archive Disk Bundle that also contains the Library – then recovery is a one launch operation, always.
    This won’t work for the large project folk on shared storage – but if you work projects at the desktop level – it’s foolproof easy.
    My 2 cents.
    YMMV.
    Creator of XinTwo – https://www.xintwo.com
    The shortest path to FCP X mastery.
  • Doug Metz
    November 27, 2017 at 8:49 pm
    It isn’t the media though… this is only about your User / Motion Templates folder, and how your custom Titles, Transitions, and Effects are displayed in the FCPX interface.
    The problem, as I understand it, is Brendan and Chris (and me and others) create new or modified effects / transitions / generators in Motion. After you’ve done this a few times, you realize a different grouping would be more efficient. So you go into your Motion Templates folder and reorganize a bit. Afterward, everything shows up just the way you want it in FCPX, perfectly usable, but some of your projects show your effects / titles / generators as Offline (even though they aren’t).
    I’ve rearranged my custom templates twice (‘cuz I’m stupid), and fortunately haven’t run into this problem.
    This is an issue with the way FCPX stores paths to your effects in the XML, not a media management or workflow issue.
    Doug Metz
    Anode
  • Chris Faber
    November 28, 2017 at 12:38 am
    The issue is that there is no way to organize custom titles inside Final Cut. If I mistakenly save a custom title that I create in a “3D Titles” category in the titles browser, when the title isn’t 3D I can’t move it to another location in the browser. The only way to move it into a correct category is to do it in the finder.
    It actually works fine in the sense that when you open up FCPX after doing this, the custom titles are where you placed them in the finder.
    The problem is that custom titles that have been used in a timeline go offline. Apple could and should fix this, and has a variety of ways it could go. The simplest would simply be to create the ability to organize custom titles and generators from within the program.
    Hey, let’s ask for that through a feature request.
    Chris Faber
    Faber Productions
    chris.f@faberproductions.com
    http://www.faberproductions.com
  • Hans Wurst
    May 17, 2019 at 10:25 am
    Hi there,
    I recently have to re edit an old project and I updated it to the newest version of final cut 10.4.6
    Now my subtitles are all offline media And I cant figure out how to make them online or rerender them.
    I think I will manually reinsert them as its only a 20min short and I have the TC text somewhere. But just to know it would be interesting.
    Im a huge final cut defender, but lately im running into quite some side effects, that dont make that program suitable for hand over and dig out of old projects….
    thanks for the help
    leo
  • Andreas Kiel
    May 17, 2019 at 7:26 pm
    You could try my X-Library Check
    This mini-app searches a library (.fcpbundle) for all fonts and external motion templates, lists them and warns if something is missing.
    Application usage: Use Menu / Button to open a Library or drag Library to the App’s Icon and wait a bit. The result/report is saved as “Library Name” & “-check.text” at the Finder level of the library.
    https://www.spherico.com/filmtools/X-Files/X-Library-Check/XLC-Install.dmg
    Spherico
    \”He who fights with monsters should be careful lest he thereby
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
  • Hans Wurst
    May 18, 2019 at 7:54 am
    Hello thanks for the advice. In the end I found an old SRT file which I could re-import as a caption. But actually I realized the titles were off-line, because back in the day i used x title importer to import titles from YouTube, before captions were supported by Final Cut.
    Haha. I remembered that was a useful tool back in the day!!!
    Thanks for the plug-ins do you do
    All the best
    Leo
  • Todd Finnigan
    July 3, 2019 at 3:23 am
    This just saved me so much time! Just yesterday I had to open an old show and re-edit it, a show from a long, long time ago. It had been archived quite some time ago. When I opened it, it had to first convert to the new version of FCPX on my computer. When I finally opened it, the titles were all offline. They did appear properly in the timeline, but I just saw the large red “T” screen where the text should have been. At first, I thought I had made the archive wrong. Fortunately, I found this discussion and used this app to research the issue. What had happened is that: 1. I had upgraded my boot drive over a year ago. 2. And I downloaded and reinstalled all the FCPX titles I had purchased on the new drive. However, the reinstalled titles had been updated by their authors and had slightly different file path names. Fortunately, I still had the old boot drive and using this app was able to identify the problem and fix it by simply copy and pasting the older title folders into the new boot drive folder. As they had slightly different names than the updated versions, there was no file name conflict, and all the titles are back. This is the closest thing to magic for this month for me!
    Thanks a ton!
  • Andreas Kiel
    July 3, 2019 at 5:01 pm
    Good to hear that the app helped to solve the problem.
    Spread the word 😉
    Spherico
