Activity Forums Maxon Cinema 4D Missing strokes using Sketch & Toon
  • Missing strokes using Sketch & Toon
    Posted by Scott Green on June 6, 2013 at 12:01 pm
    I’ve just started exploring Sketch & Toon in C4D to create a technical drawing and export it to Illustrator, however I’ve just come across a problem and no matter what settings I’ve changed nothing seems to work.
    I’ve booled 2 objects and applied the S&T material to them but there’s a line missing where the objects meet each other.
    Can anybody help me fix this please?
    This should link to my test file if it helps.
    6110_untitled1.c4d.zip
    Many thanks.
    Creative Multimedia Design Manchester | S©tt Green | Splurj
    Corrado Carlevaro replied 13 years, 3 months ago 2 Members · 4 Replies
  • Scott Green
    June 6, 2013 at 12:13 pm
    There are also too many lines in my AI export file that don’t appear in my C4D render preview, what are the correct settings should I be using in my export?
  • Corrado Carlevaro
    June 6, 2013 at 2:43 pm
    For the first missing line I set the Sketch&Toon tag to Intersection and in the Intersection menu I set Objects to “Hierarchy”.
    For the second image you should apply a Sketch&Toon tag to the inner part of the cogwheel and set the Sketch&Toon material also for “Default Hidden”
    6113_6110untitled1.zip
    Corrado
  • Scott Green
    June 18, 2013 at 2:16 pm
    OK, so I’ve managed to sort out of the parts of my model using Sketch & Toon.
    I just have one part of it where it’s not quite rendering the same as the rest of the parts. I don’t want to see the creases in it but whichever settings i select I can’t seem to find the settings I’m looking for, any advice?
    The part of the model I’m refering to is labelled ’16 Washer’
    Project file:
    6160_mechanics.c4d.zip
    Thanks in advance.
  • Corrado Carlevaro
    June 18, 2013 at 3:14 pm
    I set the Creases Min angle in the Sketc&tToon tag from the default value of 10° to 20° and I believe I got what you are after
    6161_mechanics.zip
