Activity Forums Sony Cameras missing .smi file after recording EX1R recording
  • missing .smi file after recording EX1R recording
    Posted by Flavio Ferrari on November 29, 2010 at 12:06 pm
    I have recorded some footage with a Sony EX1R.
    One clip is not usable. I can’t play it with anything and cannot convert it for use in FCP.
    Each CLPR folder is normally like this:
    ****.BIM
    ****.XML
    ****.PPN
    ****.SMI
    ****.MP4
    However the clip I want to use and that I cannot convert/play is missing the .SMI file from the CLPR folder.
    Does anyone know how I can fix this? It’s a really important piece of footage and it’s really frustrating I cannot use it.
    Any advice will be gratefully received.
    Flavio.
    Daniel Wright replied 15 years, 9 months ago 2 Members · 1 Reply
  • Daniel Wright
    November 29, 2010 at 10:46 pm
    I did a test by removing the .SMI file and found that XDCAM Transfer didn’t care; the clip played as normal. This would suggest that the missing .SMI file is not the only problem. Was the card removed before the light had gone green, perhaps?
    You could try copying the .MP4 file into a folder and adding that folder to XDCAM Transfer. If that doesn’t work, then the .MP4 file itself must be broken.
    In case you haven’t tried already, it might be worth putting the card back in the camera and seeing if you can play it.
    HTH
