Activity Forums Adobe After Effects missing safe title window
  • missing safe title window
    Posted by Kurt Murphy on June 10, 2005 at 1:48 pm
    For some reason, in one of my projects, I can’t see the safe title window. I’ve checked the View menu, but nothing indicates that I’ve turned it off. It safe title icon appears to be on, but nothing shows up when I click it on and off (or the apostrophe key). Other projects or new projects are fine though….
    thanks,
    kurt murphy
    Sean Bowerman replied 20 years, 2 months ago 4 Members · 3 Replies
  • Ace Billet
    June 10, 2005 at 6:01 pm
    I had this weird thing happen couple of times,
    usually working on BIG projects with a lot of comps inside.
    When I quit and restarted AE I could work again to some extent.
    Or try Purge (edit menu).
    I’m on a mac, doesn’t know if it makes a differnet.
    Best of all – work with a Monitor so you can see what gets chopped (if so ..)
    cheers
    ace
    Intel Inside, the world’s most popular warning label.
  • Peter
    December 22, 2005 at 5:25 pm
    Had the same thing happen – Trashed prefs and all is well again!
  • Sean Bowerman
    June 29, 2006 at 6:05 pm
    hi, i’m having exactly the same problem. how do i trash the pref file? anyone found out why this happens?
